mb944 Posted September 13, 2004 Report Posted September 13, 2004 Hi there!I would like to make a stand alone sid piano.My initial plan was to integrate a 2x40 lcd, encoder and buttons into the chassis of a small toy electronic piano,and solder the piano keys to the Dins of a midibox64 (which act as note on/off by default, which would be perfect for a basic non velocity piano). Then, I could somehow use the small amp to drive the sid output through the little integrated speakers, with switchable headphone input.I would finaly plug the midi out of the midibox to the midi IN of the Sid, and Voila.On second thoughts, It seemed a shame to have to use two cores, two PIcs and take up Twice the space to achievesomething that must be some way possible with the sid alone.This takes me to the question:How can I make 24 pins (2 octaves) of the sid's DINX2 send note on/off data directly to "itself" without losing the Encoder and button for the basic sid controller.Allthough I haven't a clue with mios software, I think a portable sid piano would be a great little gadget to take around, and will put all the effort into getting it made, so any help to get me started would be deeply appreciated.many thanks in advance,-Alex Quote
TK. Posted September 13, 2004 Report Posted September 13, 2004 Hi Alex,thats only a small routine in USER_DIN_NotifyToggle is required which forwards the toggle events of your buttons to the MIDI processor of MIDIbox SID. But: are you sure that you've a dedicated line for each button of your piano, or are the buttons organiced in a matrix?Best Regards, Thorsten. Quote
mb944 Posted September 13, 2004 Author Report Posted September 13, 2004 Hi Thorsten,Thanks, I'll put a diver's suit on and have a look in the .asm files :-/As for the little piano keys, I etched a board for them, so that each key leads to a din pin.I'll keep posting the progress!cheers,-Alex Quote
