I find this and I am horny on it-aahhh
I have found all parts - but not this
http://www.analog-synth.de/synths/tr909/909bd_pcb.pdf
I will build this: But before I have a question
Whats that-maby a operation ampliefier-
Do you now whats the full name- or a second product
072
071
And this site
http://www.introspectiv.eclipse.co.uk/
I have ordert this pcbs: but I dont find this types in Germany (Reichelt)
ZTX1051A
2SC2878 (have high reverse current gain)
2SD1469
MAX 525
NJU7304D
LM723
What meens unbufferd, what type is this
4011UB (USE unbuffered (4011 U..)device only)
4069UB (USE unbuffered (4011 U..)device only)
CAPS:
Polyester: Is this the same like Foil capacitors or is this styroflex capacitor
Polyester MKT: Is this the same like Foil capacitors or is this styroflex capacitor
I now this is much question, but when you see the partlist- its not much  ;D
hi Phattline
072
071
Thats a TL072 or TL071, a standard Op-amp.
Hey i ordered two as well,
ZTX1051A
thats the substitute for the 2SD1496. I didn´t find a supplier as well, but i will use some Fmmt691 SMD substitutes i still have from my old TR909 clone
i think you don´t need these as the muting circuit is not used.
MAX 525
Sample order at Maxim.
NJU7304D
i could find it only at Digikey in US.
LM723
should be avaible at Reichel (µA 723 DIL).
I didn´t do a search on these one, but the UB is just a special variation of the B type. It seems not so common though
i also would like to know this.
These are the standard MKT/MKS Types you get when ordering at Reichelt. The pinspacing for the Trevor board seems to be 7,5.
Hope that helps
But why do you need the NJU7304D?
chriss
I'm not betting on this, but I think that unbuffered types are the original, first generation CMOS logic. What makes it so attractive to SynthDIY community, is that those are analog devices, that are not being restricted to pure 1/0, high or low operation (buffering probably means something like Schmitt trigger before actual logic circuit forcing it to operate in logic voltages).
Bye, Moebius
