Guest romakrau Posted December 14, 2002 Report Posted December 14, 2002 Hi folks,I'm using EAGLE light V 4.06 and try to open the abovemention file. I got always an error "Error reading ..."Any suggestion?All hints and advices are welcome.Greetings Roman
d2k Posted December 14, 2002 Report Posted December 14, 2002 Hi..First off, the most recent version of eagle is 4.09r2 - not sure of the updates but u may wanna get it...To open the .brd files goto:File > Open and select 'board' from the list of filetype options. Then direct the browser to the mhbp_core_v2.brd file.Best...
Guest romakrau Posted December 14, 2002 Report Posted December 14, 2002 Hi,thanks for your help, but it is the normal way I usedto open a file in EAGLE. It shouldn't be that, withoutmajor number changed, there is a different file format.Roman
TK. Posted December 14, 2002 Report Posted December 14, 2002 I created the layouts with the Linux version of Eagle. Don't know if they are incompatible, but normaly - with the most up-to-date release - it should work.Best Regards, Thorsten.
Guest romakrau Posted December 14, 2002 Report Posted December 14, 2002 Hi folks,thank you for all answer received yet. Unfortunatelyit's don't work. I loaded down the lastest release ofEAGLE light 4.09r, but the error comes up furtherwise.RomanP.S.: I also have get an blank page if I tried to replyto this topic. After I delete all files in the cache Iwere able to wrote this lines?
Guest romakrau Posted December 30, 2002 Report Posted December 30, 2002 Hi folks,the problem is solved. A user of EAGLE tested the fileand send me the CRC (3E8EDFB7). After this I#ve seenthat my Computer convert automaticly the LINUX fileto WIN (add 0x0D to 0x0A = 0x0D0A). Now I'm able to printout the board. Greetings and a happy new Year to allRoman
