Screaming_Rabbit Posted October 24, 2004 Report Posted October 24, 2004 Does anybody have a link for a DIY MIDI through module construction page? Something like 1IN to 4 ore more OUTs.Thanks and greetsRoger
Screaming_Rabbit Posted October 24, 2004 Author Report Posted October 24, 2004 aaaahhhh.... found one:http://tomscarff.tripod.com/midi_distribution/midi_4way_dist.htmDoes one of you electronic cracks know about this cirquit gives me any latency. I mean: Is it refreshing the data (and needing processing time) or does it just amplifie the signal?
moebius Posted October 24, 2004 Report Posted October 24, 2004 Sorry, this don't work as el cheapo midi delay ;)It's just standard midi receiver followed by buffer to drive outputs: latency = propagation delay is under 100uS, and it's nothing compared to the slowness of midi itself.Bye, Moebius
Screaming_Rabbit Posted October 24, 2004 Author Report Posted October 24, 2004 ThanksThat's good! I don't want a delay. I was afraid that I would get a delay... I want to feed more devices in parallel. - The lower the delay, the better.Greets, Roger
AndrewMartens Posted October 25, 2004 Report Posted October 25, 2004 Excellent, I was just looking for one of these the other day - going to make a basic MIDI merge + driver in one box.
Lall Posted October 28, 2004 Report Posted October 28, 2004 Hi,It actually means that one output can drive up to 20 inputs.So you could expand the copy module to have 20 outputs (IC1B->IC1E) out from the single IC1A inverter. With more, you may enter into some problems...Best regards,Lall
goyousalukis Posted November 4, 2004 Report Posted November 4, 2004 Hey, I know this isn't DIY, but I bought a Yamaha MJC8 Midi Patchbay on ebay for less than $20: here's one nowhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=23792&item=3758018316&rd=1&ssPageName=WDVWThis is one of the best tools I ever bought - you can reroute your midi cables a bunch of ways without ever unplugging them. It can send any of 8 inputs to any of the 8 outputs. It doesn't merge midi though.Justin
jdutcher Posted December 14, 2004 Report Posted December 14, 2004 hi,any idea if the pic18f452 can be used as a substitute for the pic16f877 in this project?
