audax_axon Posted April 13, 2025 Posted April 13, 2025 (edited) Slightly related to another recent thread Note display in edit sometime Strange ... I've encountered a situation on my Midiphy Seqv4+ where Note 0 (C -2 in many contexts) is not correctly recognized or select-able as a drum sound - it's showing in the MIDI monitor and is passed to MIDI through - but not able to be made part of a sequence. The lowest selectable note (knob turned all the way left) seems to be c#2. This is especially troublesome since it is hard mapped to a System80 808 clone kick (unchangeable in that gears particular case). (and in fact is also the standard kick sample location on most sample sets I've built over the last decades). Is it possible that there is a range setting somewhere that is filtering this note? Edited April 13, 2025 by audax_axon clarifying note value
TK. Posted April 13, 2025 Posted April 13, 2025 c-2 is note number 0 and it's (unfortunately) used at some places to identify unplayed notes. However, I just checked how to make this possible without breaking legacy - with this new build you should be able to play this note by transposing the track. E.g. transpose by -1 octave and c-1 becomes c-2 -> http://www.ucapps.de/mios32/midibox_seq_v4_098_pre10.zip Best Regards, Thorsten.
audax_axon Posted April 13, 2025 Author Posted April 13, 2025 Wow, cool! Just loaded this up and it's working like a charm. Thanks TK! Life is good with 808 kicks
