MIDI Note 0 (a.k.a. c-2) Not Recognized on Midibox Seqv4+
Slightly related to another recent thread Note display in edit sometime Strange ...
I've encountered a situation on my Midiphy Seqv4+ where Note 0 (C -2 in many contexts) is not correctly recognized or select-able as a drum sound - it's showing in the MIDI monitor and is passed to MIDI through - but not able to be made part of a sequence. The lowest selectable note (knob turned all the way left) seems to be c#2.
This is especially troublesome since it is hard mapped to a System80 808 clone kick (unchangeable in that gears particular case). (and in fact is also the standard kick sample location on most sample sets I've built over the last decades).
Is it possible that there is a range setting somewhere that is filtering this note?
Edited by audax_axon
clarifying note value
  • audax_axon changed the title to MIDI Note 0 (a.k.a. c-2) Not Recognized on Midibox Seqv4+
c-2 is note number 0 and it's (unfortunately) used at some places to identify unplayed notes.
However, I just checked how to make this possible without breaking legacy - with this new build you should be able to play this note by transposing the track.
E.g. transpose by -1 octave and c-1 becomes c-2
-> http://www.ucapps.de/mios32/midibox_seq_v4_098_pre10.zip
