arumblack Posted December 11, 2004 Report Posted December 11, 2004 I was trying to fix a broken output jack on my korg dw-8000 and during the removal of the old jack, one of the pads lifted from the pcb. How can i safely remove the solder mask so i can solder to the trace ( the jack is not working without the pad...)?Anyone know an answer? Quote
Guest djrazz Posted December 11, 2004 Report Posted December 11, 2004 one thing i have done with broken traces /broken pcbsscrape some of the coating off of the still attached existing trace and solder a small wire to the trace then solder the wire to desired connection restablishing the original design just be carefull not to solder anything togehteralso tin(presolder ) the trace before attaching the wire this will make ading the wire in much easier Quote
arumblack Posted December 15, 2004 Author Report Posted December 15, 2004 Right, problem is the trace is covered by solder mask. Can I just scrape it off ? I would fear that would damage the trace underneath, and I'd be no better off than before.thanks,AB Quote
d2k Posted December 15, 2004 Report Posted December 15, 2004 Can I just scrape it off ? I would fear that would damage the trace underneath, and I'd be no better off than before.Just scrape it off yes! use a small flathead type screwdriver and just go gently if your concerned (you'll be fine tho ;p) once you see the original copper colour u know ur there!good luck! Quote
arumblack Posted December 21, 2004 Author Report Posted December 21, 2004 Awesome, thanks. Will try this soon! Quote
