hi
i want to build me a synth so...
which one is easier to build (considering de-soldering) ?
whixh one is cheaper ?
which one is easier to find parts (chips) to ?
which one is more friendly to work with ?
which one got a better sound ?
i know the last one is a discussion on its own and probably could be answered as it is a subject of personal taste...
but which got a deeper bass, more crisp sound, etc.
hello,
concidering desoldering the MBSID is easier; you don't desolder at all (and the MBFM aswell if you order new ic's ;))
depends on what you want; you have to read the hardware options carefully, decide what hardware you want; then you can calculate what the costs will be building it; (this is different for everyone; what/howmany knobs/encoders/displays etc)
eehm, depends on your "partfinding qualities" and your lokation, but most parts you can find in big electronic mailorders (not the cheapest solution (try ebay))
as MBFM is still in development so i don't know that; but if you know some (virtual) (subtractive?) analog synths, i think MBSID is easy to understand. OSCpitch/pulswidth/(vca)/Filter modulated by envelopes and LFO's (and if this sounds boring; you can do wavetables too)
i think this could aswell be subject of an endless discussion; best thing is to listen to the samples, hear if one of the synths has your preference; anyway i'm sure both synths have very interesting specs and sounds
in short; you probably will want to build both.... ;D
good luck; marcel
Just build the SID.
And when it's ready, build the FM.
You can re-use a lot of modules so it won't cost that much more...
The FM will have very warm, pad-ish sounds, bells, rings, generally stuff nice to the ear.
The SID on the other hand is an evil, searing analog synth.
