midibox cv: is it possible to add LFOs?
Dr_Nick
Hi!
Is it posibble to add some LFOs to the midibox cv firmware? Or midi-triggered envelope generators?
Personally, I don't have a clue how much processing power would be needed to implement some LFOs with a resolution higher than 7 bits. Any ideas?
Regards,
Dr. Nick
Hi Nick,
"is it possible" is not the right question, I guess you mean "is it much effort". My answer: yes, it is.
Just use the MIDIbox SID (or MIDIbox FM) firmware instead - they can also be used without the soundchips just to drive the AOUTs. And the internal resolution is much higher than the resolution which is provided by the DAC itself
  • 6 months later...
hi,
one more question , could the gate be enabled by incoming midi note , i've explored the app files ,but didn't find the way to do it.
or maybe the midi to gate conversion routine have to be extracted from the mbCV app?
I just logged in after a long time (doing diy with the analogue stuff and building up a studio) to look for an application recommendation for digitally controlled lfo's...and voila...
Amazing, there's still new fascinating stuff in the apps section...
(Just looked for midicv and stumbled upon this thread - Analog Tools! Cool!!!) 8)
Thanks again Thorsten.
