bosone Posted January 29, 2005 Posted January 29, 2005 i'm thinking about migrating from old midibox 16 with pic16F and pots to midibox 16E with pic 18F.the question:is the box usable without ledrings? anyone has experience and comments??is it possible to implement BOTH encoders and analog 10K pots?? how can i do it?? should i customize the MIOS code??? ideas?
moebius Posted January 29, 2005 Posted January 29, 2005 i'm thinking about migrating from old midibox 16 with pic16F and pots to midibox 16E with pic 18F.the question:is the box usable without ledrings? anyone has experience and comments??is it possible to implement BOTH encoders and analog 10K pots?? how can i do it?? should i customize the MIOS code??? ideas?Why are you giving up your beloved 16F-core?It will work without ledrings - Yes, pots and encoders work at the same time.. IT IS APPLICATION code, that needs some adjustment.. as far as I remember, It has been done.. sorry.. can't find a link. I think it was based on Midibox64E with AINs enabled?Bye, Moebius
