dstamand Posted January 9, 2009 Posted January 9, 2009 Bulk order : http://www.midibox.org/forum/index.php/topic,12771.msg107841.html
Jack Posted January 28, 2009 Posted January 28, 2009 Hi,I thinking about DIY led rings, see my attachments.But I don't know how build the upper part.Best RegardsJack
dstamand Posted January 28, 2009 Posted January 28, 2009 Hi,I thinking about DIY led rings, see my attachments.But I don't know how build the upper part.Nice job, i like it. The upper part could be done with two tin Acrylic sheet and film mask between both
Sasha Posted January 29, 2009 Posted January 29, 2009 Nice job, i like it. The upper part could be done with two tin Acrylic sheet and film mask between bothHere is how I did it. This is the test. I have some finished rings. I`ll post the pictures when I back home.EDIT: This is what I did. I sprayed one side of transparent acrylic sheet with layer of primer and several layers of black paint than laser etched and cut the rings. Doing it with film makes not much sense as you are already using machine for cutting. Why not to engrave it when it is already in place? ;)
yota Posted March 22, 2010 Posted March 22, 2010 i found this in a spanish distributor, i ask for price and sell conditions. the indicator has 23 led conected in a led matrix of 8 pins. Circular indicator 21 led and 2 red leds in center. my doubt i to connect the led matrix to the dout. i post more info when i have!!
alekzander Posted January 20, 2011 Posted January 20, 2011 I stumbled over two more interesting sources for LED ring assemblies. A complete assembly, SMD/through-hole, http://top-up.so-buy.com/front/bin/ptlist.phtml?Category=336089 They also have illuminated pots, encoders and switches. Small PCB with shift register SMD mounted LEDs and encoder for interfacing via SPI http://mayhewlabs.com/products/rotary-encoder-led-ring A.
strophlex Posted January 25, 2011 Posted January 25, 2011 A complete assembly, SMD/through-hole, http://top-up.so-buy.com/front/bin/ptlist.phtml?Category=336089 They also have illuminated pots, encoders and switches. These look nice, hope they will be cheap...
