d2k Posted January 6, 2003 Report Posted January 6, 2003 Hi...Reichelt has got back to me but have said that the RAD1/16 and 10/16 are 'not in program', and put down these 2 as replacements:RAD 10/16 [original] RAD 10/35 ELKO 5X11 RM2,0 [Replacement]RAD 1/16 [original] RAD 1/63 ELKO 5X11 RM 2.0 [Replacement]I assume they're fine, but thought I might aswell check beforehand...Thanks in advanceDan
d2k Posted January 7, 2003 Author Report Posted January 7, 2003 On a diff tip, but still a parts q...I got my microchip samples which included the IC's for the banksticks - 24LC256. I also got the AA and FC versions, they appear the same but just they're voltage range is different I think. Are these suitable? i hope so...Cheers...
d2k Posted January 7, 2003 Author Report Posted January 7, 2003 and again...;)Do Reichelt do caps for pushbuttons?I've tried navigating the site but aint got very far...I'm after some round and rectangular ones for 2.8 and 3.2mm posts...Peace...
TK. Posted January 7, 2003 Report Posted January 7, 2003 Hi Dan,the replacements are ok.AA and FC versions will work - AA means a lower minimum voltage, FC is the high-frequency version. But in fact all EEPROMs will workNo, Reichelt has no caps for pushbuttons.My recommendations:DT_6 (simply the best)TASTER_3301B (the cheapest, can also be used without knobs)DTL_2 (with integrated LEDs, but expensive)T_250A (vintage style)Some buttons are indicated with an additional code for the colour: bl (blue), ge (yellow), gr (grey), gn (green), rt (red), sw (black), ws (white)Best Regards, Thorsten.
