ohmstudiste Posted March 9, 2005 Posted March 9, 2005 I bought a LCD, which datasheet can be found here:http://www.datasheetarchive.com/datasheet/pdf/10/1006625.htmlI was told it should be ok for a use with MidiBOX (Sid in my case) but just wonder about voltage, if it's ok and if I have to do something special with voltage or just solder the connection and don't bother.I'll use a C64 PSU with a 6581 and make the C64 optimized PSU (step C) connection.Thanx in advance
banneduser Posted March 9, 2005 Posted March 9, 2005 That was quite a datasheet ;)This is a better one: http://www.dst-gmbh.de/dvkat/dv20210.htmIt seems like pretty typical LCD with normal LCD contrast (LCD drive, Vee) voltage, so it should be ok.. as always, try to get the connection right in the first try ;DBye, Moebius
