Julian Posted March 11, 2005 Posted March 11, 2005 hello again...at the moment I'm wondering how to connect a midi thru to mid SID.where do i connect the LTC? as the port is allready used for the core interconnection...best,julian, gettig closer to the finished box.. ^^
TK. Posted March 12, 2005 Posted March 12, 2005 Hi Julian,so long the LTC is used in passive mode (MAX232 not connected), you can connect the LTC in parallel to the other core modules - it's just a "signal reader" in this case, the 74HC00 amplifies the Tx and Rx signal so that the additional LEDs/MIDI ports don't load the signal lineBest Regards, Thorsten.
Julian Posted March 12, 2005 Author Posted March 12, 2005 thanks!tryed it and it works now :)bst,julian
