BigEar Posted May 5, 2005 Posted May 5, 2005 Hello!For making my MidiBox I've 16 100mm faders, but I didn't pay attention to their's type. As it turned out they are of logarythmic type, so now I can't use them for my MidiBox with standart Software. Is there any software solution to use logarithmic potentiometers instead of linear? Thanks in advance.
Screaming_Rabbit Posted May 5, 2005 Posted May 5, 2005 Did you try to exchange them? This shouldn't be a problem (... at least not here in Switzerand).Greets, Roger
BigEar Posted May 6, 2005 Author Posted May 6, 2005 Unfortunatelly in Russia this is a great problem. But still thanks for suggestion :)
intosite Posted June 30, 2005 Posted June 30, 2005 If not mistaken you still can use log faders.You just won't be able to have fader in the center when 50%Most audio equipments seem to be using log faders.I also have a few and quite some time back i had a thread asking if there is a way to make them linear...Answer was there is, but its quite troublesome and worth more your while getting new ones.Cheers
Screaming_Rabbit Posted June 30, 2005 Posted June 30, 2005 If not mistaken you still can use log faders.You just won't be able to have fader in the center when 50%Most audio equipments seem to be using log faders..... you can't compare that. In DAWs, the host is doing the log calculation. In a MIDI Controller, it's a linear ratio of position to loudness. I think you can't really mix anymore when you reach the top end of the fader position.And making a nice sounding fade with a hardware fader, is like learning to play a musical instrument... you get used to the speed it takes to get the fade you'd like to hear. - Imagine, you suddenly have an absolute different ratio of movement to loudness behavior. :(Greets, Roger
