bosone Posted May 10, 2005 Posted May 10, 2005 i'm currently building my new midibox, and i will mount both 16 pots and 16 encoders.but i have decided not to mount 16 ledring for each encoder (TOOOO much work...), and to use them without indication.but i was thinking this:is it possible to mount only one "ledring" (in the form of a meter... i.e. not a "ring" but several led in a straight line) and assign this only one ring to every encoder?my idea is that, when i move an econder, this single ledring will monitor the state of the encoder that i'm moving.... swithcing its state depending on the encoder used in that moment....i will not monitor the status of every encoder, but only see a single encoder value...
TK. Posted May 10, 2005 Posted May 10, 2005 Hi Matteo,it's impressing that you are never giving up to save money and effort ;-)A change should be simple, open mb64e_ledrings.inc and replace following lines: incf MB64E_LEDRINGS_CTR, W, BANKED andlw 0x0f movwf MB64E_LEDRINGS_CTR, BANKED[/code] by: [code] ;; always display status of last modified encoder movff MB64E_LAST_ENTRY, MB64E_LEDRINGS_CTRBest Regards, Thorsten.
bosone Posted May 11, 2005 Author Posted May 11, 2005 ahaha!! :-)thorsten, you are right! i try always to achieve the maximum i can with the minimum expense...also this is part of the funny to build the midibox! :-)there is always the behringer BCR control to buy, if one wants the simple things!!!(this topic could also be name: "one ledring to rule them all".... i'll throw my MidiBox in the flames of Mount Doom... ;-) )
bosone Posted May 22, 2005 Author Posted May 22, 2005 Hi Matteo,it's impressing that you are never giving up to save money and effort ;-)A change should be simple, open mb64e_ledrings.inc and replace following lines: incf MB64E_LEDRINGS_CTR, W, BANKED andlw 0x0f movwf MB64E_LEDRINGS_CTR, BANKED uhm.. i tried but it didnt worked. when i change encoder, the leds simply turn off... by: ;; always display status of last modified encoder movff MB64E_LAST_ENTRY, MB64E_LEDRINGS_CTR Best Regards, Thorsten.
TK. Posted May 22, 2005 Posted May 22, 2005 How did you connect the cathodes of the LEDs, and to which shift registers (SRs) are the anodes connected?Best Regards, Thorsten.
bosone Posted May 23, 2005 Author Posted May 23, 2005 the connections are the one indicated in hte schematic.only one ledring is presetn: the cathode to SR1, and the 11 leds to SR 3 and 4...
TK. Posted May 23, 2005 Posted May 23, 2005 So, with a single LED ring it makes sense to connect the cathode line directly to ground, so that it is always poweredBest Regards, Thorsten.
