QBAS Posted July 11, 2005 Posted July 11, 2005 HELLO THORSTEN KLOSE!MAYBE IT IS A STUPID QUESTION ???I CANNOT UNDERSTAND WHY WHEN I SET IN main.asm UNDER General Aplication Settings :#define INITIAL_DISPLAY_PAGE 3OR #define INITIAL_DISPLAY_PAGE 1FOR TAKE A METERS ON LCD . In MBLC v.1.5 - METERS RUNS (WORKING) IN MBLC v.1.6 - METERS ON LCD not working ???THANK YOU FOR RESPONSE QBAS
TK. Posted July 11, 2005 Posted July 11, 2005 Hi,first I would suggest to take a screwdriver, open your computer keyboard with it and check the contact of the CAPS-LOCK key, it seems that it is stucked ;-)Could you please check if the same problem exists in this release: http://www.ucapps.de/mios/midibox_lc_v2_0_alpha1.zipBest Regards, Thorsten.
QBAS Posted August 2, 2005 Author Posted August 2, 2005 Hello TKSorry I`m very late with the answer:in midibox_lc_v2_0_alpha1.zip everything with meters on lcd works great.My late is because I`m try to write the assembler code for catch sysex .(I`m talking about idea ; not about details)So - if I will not do this I will ask on the Forum .I don`t wonna waste your time if I can try learn assembler . :Pwith greetingsQBAS
