Seems to be a KS0107/0108 compatible display - very good, should work! :)
Just let the CS3/CS4 outputs of the core open, the driver will regognize automatically that the appr. segments are not available
Alternatively you could connect a second GLCD in parallel to the first one, with the only exception that the chip select lines are connected to CS3/CS4, which results into an effective resolution of 256x64 (good for MIDIbox LC)
