SounDuke Posted July 29, 2005 Posted July 29, 2005 Hello, I'd like to buy this GLCD http://www.delta-opto.com.tw/PRODUCTS/module-PDD2401GM04%20Spec.pdf but the IC driver is not mentioned. The pins are compatible, except for CS3 and CS4 that are missing. What do you think?
TK. Posted August 3, 2005 Posted August 3, 2005 Seems to be a KS0107/0108 compatible display - very good, should work! :)Just let the CS3/CS4 outputs of the core open, the driver will regognize automatically that the appr. segments are not availableAlternatively you could connect a second GLCD in parallel to the first one, with the only exception that the chip select lines are connected to CS3/CS4, which results into an effective resolution of 256x64 (good for MIDIbox LC)Best Regards, Thorsten.
