Milkmansound Posted August 9, 2005 Posted August 9, 2005 hello - I am about to start on another exciting midibox venture - and I think I would like to use the USB implementation on this one. Here is my dream: Midibox64 design, powered by USB that will be a dedicated control surface for Ableton Live/DAW mixing - with external power and midi (switched)so, here are my questions:1 - is that possible?2 - will the USB allow me to pass midi on to the core and back under OSX?3 - will I need to burn an eprom? If so - how do I go about doing that (I can use a PC if need be)thanks!
raphael Posted August 9, 2005 Posted August 9, 2005 1 - is that possible?Yes, but one USB port can only deliver 500mA (maximum - most laptops only deliver 100mA!). Keep that im mind. So, don't tihnk about a LCD with backlight... 2 - will the USB allow me to pass midi on to the core and back under OSX?I think the MB USBModule is supported under OSX. Should be OK.3 - will I need to burn an eprom? If so - how do I go about doing that (I can use a PC if need be)Why do you think, you will have to programm a EPROM? The MB USB module uses a EEPROM similar to the bankstick module which is programmed via the AN2131SC (which is programmed via USB). No special equipment needed.Raphael
Milkmansound Posted August 9, 2005 Author Posted August 9, 2005 thank you for taking a moment to asnwer those! Looks like I am good to go - I will see if I can find the output amperage of my USB on my ibook for an LCD - but becklighting is not essential.
