VilladonEnt Posted September 8, 2005 Posted September 8, 2005 Hi Everyone,I am new to this forum and I have a couple questions.I am starting my midibox64 project and this is the setup i would like to accomplish.25 Potentiometers 2 60mm Faders1 100mm Faderand about 85 buttons..From reading this forum I gather that I'll need..2 cores1 ain3 din1 ltcI just received 1 core kit and 1 ain kit from SmashTV (Thanks!) to get started..If I purchase the rest above will that be correct?Another question, Is it a difficult process to link two cores together, using 1 LCD, 1 midi in and 1 midi out?Thanks.
illogik Posted September 8, 2005 Posted September 8, 2005 hi; yeah this is correct; but you don't need a LT; every core has a midi in and midi out port; the ltc is for if you want midi through, an extra midi out or a midibox to com port. extra out and trough is nice to have in my opinion though..and if you can do with less buttons (like 64, mios/midibox apps are very flexible) you can do it with 1 core and 2 dinx4 but linking is easy too ;Dgood luck, marcel
VilladonEnt Posted September 8, 2005 Author Posted September 8, 2005 Thanks Marcel!I'm going to place the rest of my order tonight.I'd love to cut down on the buttons, But I'd rather cut down on using the mouse. ;DI had SmashTV program Pic with the bootloader and pic id header equal to sysex Device ID: 00So having him program the next Pic with the bootloader and sysex Device ID: 01 would be ok?smash has 1 meter ribbon cables, to be safe how many would you order to wire this project. Just a ballpark figure.Thanks for your help!I'll be soldering away tonight! :DJason
