I've been studying the MIDIOS system, so far I'm a bit confused... ???
I think I want to build a midi box64 - I say think because I either need that or the MIDI0128 - to process MIDI data for this project:
http://www.stephenhobley.com/Site/content/view/36/55/
It seems that all the parts for a MID box 64 are available from
http://www.avishowtech.com/mbhp/buy.html
So I need to buy a core module, and the DIN module?
I think I'll order the DOUT and AIN as well in case I ever decide to use them.
Do I need the PIC programmed with the bootstrap loader - it appears that I do. Also what should I put in the PIC header ID field when ordering? I don't know what this means.
If someone wiser could help me out it would be appreciated.
Thanks!
Steve
Looks realy cool 8)
What application you need depends on what you want. If you just want to send Note ON/OFF MIDIO128 is the simplest aplication you can use. But as all the application use the same hardware modules, you could change to MB64 later.
Yes thats the simplest setup to midify your laser harp.
If you have no PIC programmer, order it with already burned bootloader.
Have you read this page: http://www.ucapps.de/mios_bootstrap.html
The ID depends on the display you use, the SysEx ID for the Core and the Interface type.
There is a easy-to-use ID calculator on SmashTV's site: http://avi.dezines.com/mbhp/idgen.html
To have different SysEx IDs is only important for Multi-Core setups like the MidiBox SID with 4 cores. So just choose 0x00 for your first Core.
If you don't want to use a display, just choose the "character" type as this is the most commen display type.
So just order a PIC with ID = 0000000000000000. (Assuming you want to use MIDI and not RS232 connection).
Hope this helps,
Raphael
