Hi List
Today is the day when I moved from PIC16F877 to the new one - 18F452 with MIOS.  Loading the firmware was no problem. It works fine, but:
when I turn a pot (doesn't matter which) to a value <15 the LCD turns off. When I move it backto the value above 15 the LCD turns on. When it is turned off and i touch other pots (to send value above 15) LCD turns on again.
Last, when LCD doesn't display anything, midi-ox recives some values so the box is working.
A didn't have such an issue with 16f - everything workeg fine, so hardware is i suppose ok.
Any solutions?
Andrew
I've measured voltage on power lines with all leds on: 5,05V (and the LCD down).
I checked the old PIC16F and old osc. - it works!
I've also uploaded the application midibox64v2.4 once again, still no success :(
Andrew
