zxkxki Posted October 17, 2005 Posted October 17, 2005 Hi midibox tweakers i am wondering about the functionality of the midibox sid.A 1 x midibox sid has 1 monphonic channel and a 4 x has 4 mono or 4 polophony ? i know you could stack sounds maybe on 4 channels in realtime but can it do like 4 x poly tricks or patch the 4 sids to same midi ch and then trigger as one patch . . .? . . . . . i wondered if a very nice feature was possible where in future it has like Monopoly korg type setting where if you play 4 notes in a sequence it plays sid 1 , then 2 then 3 then 4 which is really cool for syncapated sequences .The vermona Performer also does this i heard.Very groovy sound.Can anyone explain the 4 vs 1 sid thing.Do i really need 4 if i use hardisk recorder anyway and dub stuff alot or does it offer polophony and ability to do pad sounds and layers easiliy I know it means you can have 4 monophonic sid sounds on 4 channels ? Also ? has anyone combined midibox sid and midbox sequencer yet ? into one mad mad sid groove sequencer ?so many questions :)thanks for the inspiration with this mad mad device.zx
kokoon Posted October 17, 2005 Posted October 17, 2005 one sid = 3 oscillators = 3 note polyphony.four sids = 12 oscillators (obviously) but the super-poly mode hasn't been implemented yet. though you can route midi events to the separate sids manually (each sid can be assigned it's separate midi channel)
TK. Posted October 17, 2005 Posted October 17, 2005 Hi,Also ? has anyone combined midibox sid and midbox sequencer yet ? into one mad mad sid groove sequencer ?-> see http://www.ucapps.de/midibox_seq_tutorial1.html :)Best Regards, Thorsten.
zxkxki Posted October 20, 2005 Author Posted October 20, 2005 cheers for the tips.I need to look into this site more.Its deep :)
