TK. Posted October 31, 2005 Posted October 31, 2005 Finally the JDM replacement is officially released: http://www.ucapps.de/mbhp_burner.htmlThis PIC programmer is not so easy to build compared to the JDM, but it should work much more reliable with newer PC hardware due to the external voltage source. Another advantage is, that the P18 programming software is more up-to-date than IC-Prog, all relevant PIC18F derivatives which will be used in future (PIC18F452, PIC18F4520, PIC18F4620, PIC18F4550) are supported.Sidenote for Newbies: this statement can be found at many places of my website, but I will mention it again to avoid confusion: this module is directed to people who buy blank PIC devices directly from a shop or distributor, and who want to program the MIOS bootstrap loader, or any other firmware into the PIC.If you only plan to build a small number of MIOS based projects, I strongly suggest you to get use of the perfect and inexpensive programming service of Mike or SmashTV!Best Regards, Thorsten.
titan Posted November 6, 2005 Posted November 6, 2005 When will it be available on SmashTV?Greetingstitan
TK. Posted November 9, 2005 Author Posted November 9, 2005 This question has to be answered by Smash himselfBest Regards, Thorsten.
