Up Load
the sound
Hi
I Have a Core, Din and a 2 by 20 LCD Hooked up.
My PIC is Number 1 So I changed the SyxString (F0 00 00 7E 40 00 01 F7) to
(F0 00 00 7E 40 01 01 f7) every were I saw it in MIDI-OX . Then I uploaded  it and on my display It went through the loading process and came up MIOS 1.08 then Ready
So all is good so far I think.
Then I go to up load {midibox64e} I changed the SyxString Again and upload
Now after rebooting I get
Loading Setup  p n
From Bank Stick ------    Flashing
So I am Stuck And have no idea what to do
I might of missed changing the Pic ID on one String of the midibox64e upload
Also is there a way to erase every thing but the Bootloader and start all over
regardless if the application is running or not, you are always able to overwrite it with the first level bootstrap loader, which is active 2 seconds after power-on. So, just switch off/on the power supply, and start the transfer immediately. This will help.
Another point: I would suggest the use of MIOS Studio, where you don't need to change the device ID manually
OK thank You again
MIOS Studio worked great for uploading 1.8
I think I had a bad Optocoupler also
Now the LCD will say READY
I upload the midibox64e HEX file it will load and reboot
Then Hang on *format bank 1 for ever
I have Bank Sticks to use but have not connected them yet to keep it easy at first
Any Ideas
Thank You for all your help
