TK. Posted November 15, 2005 Report Posted November 15, 2005 You got it! So long MIOS is not running, you cannot expect that the MIDIbox SID or any other application is doing anything.So, first try to debug this, offe already gave you the link to the debug page, unfortunately you didn't answer him, therefore nobody knows, if you tried this or not, and it's no surprise that you are confused by all the hints which don't work, if you haven't checked the basicsDon't give up! But install the software step-by-step please.Best Regards, Thorsten. Quote
tokyomatik Posted November 16, 2005 Author Report Posted November 16, 2005 ok guysi fixed the connection j2 - j10included the 5v from the psu to j2 of the sidbut the problem with MIOS stillwith MIOS studio i did like thislaunch the applicationconfigure the connections for the midi interfaceopen the midi in midi out monitor windowsopen the hex upload windowbrowse > mios 1.8 folder > hex folder > mios 1.8.hexswitch on my midiboxafter the message"F0 00 00 7E 40 00 01 F7"appearde in the midi in monitor i started the uploadthen i got the message "upload process complete"but the message"F0 00 00 7E 40 00 01 F7"still coming on midi in monitor every 2 secondso well i don't know, but to me the upload process seemed easy, something did'nt worked properlyanyway i did it also with SysExBexlike this:launche the applicationconfigure the midi interfaceclick "Open SysEx File"fmios 1.8 folder > mios_1_8.sysex (bytes to sent 15392 - blocks to sent 13)swich ton the midiboxafter the message"received sysex blocks from device 00 with 0 bytes in mios format - cmd 01 (not saved)click " send SysEx"but after a while the process lokks like frozenbytes to sent 7104 - blocks to sent 6the message "received sysex blocks from device 00 with 0 bytes in mios format - cmd 01 (not saved)stilllet me try also with midi oxi'll let you know... but i'm so sad that is not workingthe procedure should be easy but what can i say?HELP!! Quote
offe Posted November 16, 2005 Report Posted November 16, 2005 ok guysi fixed the connection j2 - j10included the 5v from the psu to j2 of the sidbut the problem with MIOS stillDid you have a look at the MIDI Troubleshooting link (http://www.ucapps.de/howto_debug_midi.html)? First, check all soldering points, then check component orientation, then go through the tests in the link above. I'would be more specific if I could but without any more info it's impossible. I know it can be frustrating, but as Torsten wrote, try to isolate one problem at a time.Keep up the work!/offe Quote
TK. Posted November 16, 2005 Report Posted November 16, 2005 Could you please write down the checksum of each block which has been uploaded? This info is print by MIOS Studio during the upload. It would allow us to doublecheck, if this procedure was really successful.Best Regards, Thorsten. Quote
tokyomatik Posted November 16, 2005 Author Report Posted November 16, 2005 sorry guys if i'm answering so late but today i was out of town, anyway yes, last night i tryed also with the midi troubleshootingand i will try again later because i'm far from my box nowapparently everything was allright....i'll let you know tomorrow, today i'm a bit messedthanx again Quote
