Antonio Posted December 10, 2005 Posted December 10, 2005 Hello Everybody.I'm starting to build a second core module to use as a slave in my MIDIBOX SID.In order to save components and time, I wonder if it is possible to avoid to solder some components that I suppose are used only by the master core.Here is the list of the components i would like to save:transistor, resistors, pots of the LCD Display Driver; (T1, R3,R4, P1, P2)J4-J5-j6-J7-J8-J9-J15 connectorsMoreover, since I Use an optimized PSU, i don't solder in each core module the diode bridge, the voltage regulatore 7805, and C5 and C6 caps.Is it correct?My core module will run?CiaoAntonio
raphael Posted December 10, 2005 Posted December 10, 2005 transistor, resistors, pots of the LCD Display Driver; (T1, R3,R4, P1, P2)J4-J5-j6-J7-J8-J9-J15 connectorsMoreover, since I Use an optimized PSU, i don't solder in each core module the diode bridge, the voltage regulatore 7805, and C5 and C6 caps.No problem, I also left these out.
