Hello,
I have always get an error when I try to compile a c application
below are some examples of my problem (no modifications were made to the c apps)
and the contents of my path variable
I have installed sdcc v2.5, perl and gputils-0.13.2-1.exe to e:\miosc
E:\data\midibox\analog_toolbox_v1_1c>make
Makefile generated.
Makefile.bat generated.
Assembling MIOS SDCC wrapper
Compiling eg.c
Processor: 18F452
e:\miosc\sdcc\bin\sdcpp.exe: eg.c: No such file or directory
ERROR!
E:\data\midibox\clockbox_v1_0>make
Makefile generated.
Compiling mclock.c
Processor: 18F452
e:\miosc\sdcc\bin\sdcpp.exe: mclock.c: No such file or directory
ERROR!
PATH=e:\miosc\sdcc\bin;e:\miosc\gputils\bin;E:\miosc\perl\bin\;etc...
Michael
note this error message:
[tt]
[/tt]
[tt]
[/tt]
how and from where are you starting the make.bat?
hello thorsten
thank you for your time and your quick reply  :D
I'm starting the bat file from the dos terminal (run cmd.exe)
then I navigate to the folder wich contains the app directory,
for the analog toolbox: E:\data\midibox\analog_toolbox_v1_1c
then I type make and press enter...
below is the content of the analog toolbox directory:
E:\data\midibox\analog_toolbox_v1_1c>dir
De volumenaam van station E is LOCAL
Map van E:\data\midibox\analog_toolbox_v1_1c
18/12/2005  15:51    <DIR>          .
18/12/2005  15:51    <DIR>          ..
10/11/2005  23:34            6.202 aout.c
10/11/2005  23:34            3.479 aout.h
10/11/2005  23:34              305 CHANGELOG.txt
10/11/2005  23:34              207 clean.bat
10/11/2005  23:34            13.413 cmios.h
10/11/2005  23:34            18.671 COPYRIGHT.txt
10/11/2005  23:34            3.978 eg.c
10/11/2005  23:34            2.583 eg.h
10/11/2005  23:34            7.216 eg_table.inc
10/11/2005  23:34            2.951 lfo.c
10/11/2005  23:34            2.139 lfo.h
10/11/2005  23:34            7.473 lfo_table.inc
10/11/2005  23:34            7.751 main.c
10/11/2005  23:34            2.350 main.h
10/11/2005  23:34                66 make.bat
18/12/2005  16:29            1.128 Makefile
18/12/2005  16:29            4.345 Makefile.bat
10/11/2005  23:34            1.469 MAKEFILE.SPEC
10/11/2005  23:34            6.262 map.c
10/11/2005  23:34            3.019 map.h
10/11/2005  23:34            3.384 midi.c
10/11/2005  23:34            2.343 midi.h
18/12/2005  15:51    <DIR>          mios_wrapper
10/11/2005  23:34            5.377 pic18f452.c
10/11/2005  23:34            21.979 pic18f452.h
10/11/2005  23:34            17.302 project.hex
10/11/2005  23:34            1.118 project.lkr
10/11/2005  23:34            7.104 project.syx
10/11/2005  23:34            8.610 readme.txt
18/12/2005  15:51    <DIR>          tools
18/12/2005  15:51    <DIR>          utils
18/12/2005  15:51    <DIR>          _output
              28 bestand(en)          162.224 bytes
              6 map(pen)  18.034.728.960 bytes beschikbaar
thank you very much,
Michael
So, everything seems to be on place.
Are you working with Win98 or WinME? Then it might be useful to add the PATH extensions into the C:\AUTOEXEC.BAT file, and to reboot the PC
Hi Thorsten,
Yesterday I tried installing the compiler etc on my girlfriends computer,
everything works as expected...
I will try again on my computer after I finish my exams
bye,
Michaël
  • 5 months later...
Old topic, but I still have this (still compiling on girlfriend's pc  :P)
I have a problem with the make macros when I compile a c project
everything works fine on my girlfriends computer
(even when I compile the source files from my own pc over network)
but on my computer I allways get the same errors (see below)
error message:
Makefile generated.
Compiling iohandler.c: No such file or directory
ERROR!
I can make it work on my computer if I manually edit the makefile.bat file
and add the absolute paths to the source file
after running the the make:
I've replaced this
echo ==========================================================================
echo Compiling dseq.c
sdcc -S -mpic16 -p18F452 --fstack --fommit-frame-pointer --optimize-goto
--optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector -DDEBUG_MODE=0
dseq.c -o _output\dseq.asm
if errorlevel 1 goto end_error
perl tools\fixasm.pl _output\dseq.asm
gpasm -c _output\dseq.asm -o _output\dseq.o
with this (I've added the absolute path to c source file)
Z:\firstdseq\dseq.c -o _output\dseq.asm
and so on for each c file...
can I modify the mkmk.pl script to add the absolute path
so I don't have to do this manually?
Hi Michaël,
it seems to me, that the cd to your working directory hasn't been recognized properly, or maybe SDCC srewed up, because it didn't expected to be installed on E:\ but to compile on Z:\?
I know SDCC supports installations in other folders than the default one, but I'm not sure it can also be installed on other than the system's partition? Do you know if that's supported for your installed SDCC version?
(I expect your girlfriends computer just has C:\ ;D)
I would try moving your project (or better: a fresh ClockBox-Example) to E:\ and try if it compiles from this partition...
Regards,
Michael
Wow I reckon it might be about time to rebuild that PC huh :)
Hi Stryd
I probably *should* format my pc and change my drive letter to C:\
but I rather spend some time on my midibox project than reinstalling everything from scratch ::)
Hi Michaël,
Regards,
Michael
Hi Michael,
I did try to compile the standard clockbox project from
e:\clockbox
same results...
the Z drive is a network drive mapped to my midibox directory,
I did the same on the other pc (mapped to same dir on my pc)
and it works fine
the really strange thing is:
C mapped to e:\data\electronics\midibox
doesn't work
[any drive letter] mapped to e:\data\electronics\midibox\firstdseq (->project dir)
works fine
thank you for your help,
Michaël
Haven't read the whole tread but try using sysinternals ntfilemonitor. Set it's filters and run the compilation. Then look at the log for NOT FOUND files.
