stryd_one Posted August 4, 2006 Posted August 4, 2006 Man, is it just me or are 10 people doing the same thing at the same time here? ;)Would anyone be interested in starting "the PGA Thread" and getting together on this?
bionix Posted August 4, 2006 Posted August 4, 2006 hmm.. could you use cs8414/cs4334 to support optical/spdif?
lylehaze Posted August 4, 2006 Posted August 4, 2006 OK, I started a new thread..If I got it wrong, go there and correct it!LyleHaze
stryd_one Posted August 4, 2006 Posted August 4, 2006 http://www.midibox.org/forum/index.php?topic=7280.0:)
Artesia Posted August 9, 2006 Author Posted August 9, 2006 bionix.. the audio mixing is happening in the analog domain... if analog to digital & digital to analog conversions are desired.. thats another module board that can be built sepperately..(on general topic: ..crikey, quite afew people working on this one by now too...)
bionix Posted August 10, 2006 Posted August 10, 2006 ok, we should - if we want ;) - discuss that in the new thread.the idea of optical in/out is just to eliminate some ground loops with different connections between laptop/pc soundcards and f.e. midiboxsid etc. because analogue signals from soundcard (at my laptop audigy zs 2) can get ground loops through their psu, but if they switch to optical mode, there's no ground loop. that's because the da/ad conversion is proccessed directy in front of the analogue output and the digital signal (the real signal, not the signal level) wouldn't get touched by transport over digital ways. but some reported, that also cinch and spdif out ports got ground loops, so i decided to ask about the optical (TOS) way.currently i'm at testing optical out/in conversion, to build such a little module. but i recognized little problems with different variations of data streams (from vendors and signal types like dts/dd2, raw etc.) which cannot be handled through above chipsets.maybe i find a cheap solution - this could take some time, because the current cost per channel is around 15-20 euro. remember: it's just a signal transceiver from analogue to optical and back.best regards...
