Jaicen Posted January 30, 2006 Posted January 30, 2006 Hey guys, I was was thinking of building a floorboard for my Flextone II based on the project here. The thing is, I have a few spare PIC18F452's I was hoping to use. Do these support the source code, or do I have to use the one specified (i'm trying to keep costs down). I think I understand how to modify the code to do what I want (using 4 patch buttons and 2 bank up/down buttons Maybe FX on/off), since Line666 were kind enough to publish the program change parameters in the manual. I might just go ahead and order another PIC unless anybody can suggest otherwise. Anyone ever built something like this??
TK. Posted January 30, 2006 Posted January 30, 2006 Maybe somebody wants to try to re-program the floorboard on a C based MIOS application?http://www.ucapps.de/mios_c.htmlIt's simple!Best Regards, Thorsten.
Jaicen Posted January 30, 2006 Author Posted January 30, 2006 Sounds good to me, but i'm no better at C than any other assembly code! The last programming I did was on the C64 about 10 years ago! Back then moving a static sprite across the screen really was an achievement!I really like the look of this project, it seems quite a simple build. I'm quite happy to make layouts available if somebody can help with the code.
ttruga Posted March 31, 2006 Posted March 31, 2006 Hi everyone, Im doing a similar thing with a behringer GX210 Guitar Amp. Ive got this Guitar amp who comes with an embedded Guitar Effect array which are also midi-controllable. The implementation of the midi messages are really simple, for example to change patch (for example to switch between delay or distortion) i have to send a program change message and u can configure the guitar amp to listen only on one midi channel or in all. I check on all the proyects and i guess that i can do everything with 3 pot encoders (parameter effects configuration), 2 analog pots (volume pedal and whawha pedal) and 12 buttons (2 for up/down patch functions and 10 for presets) and the code already developed for the midibox 16. any commentary are welcome,ttruga
