vix Posted February 7, 2006 Report Posted February 7, 2006 hii'm in the final part of my Sid works (2 sids with CS step C).My 2 sids was working perfectly when i realised the main part of the project. But now, after i got my control surface working well, my master sid don't give any sound ! More, my second sid works, but only via the "link", if i play on the chanel defined (2) it doesn't work... And there is an hudge noise (like psu probs, but strange)I checked my wiring, my Sid app, i changed the 2 74HC595, everything seem to be ok...any idea ? ;D
vix Posted February 8, 2006 Author Report Posted February 8, 2006 ok, i checked my slave.asm and now my second sid respond to the good chanel. But the master one (i checked and reuploaded the main file) don't sound at all... i think maybe my SID chip is dead :'( but how can i be sure ?i'll try to intervert the 2 sid chips, but i don't want to kill my workin' one....help :-\
vix Posted February 8, 2006 Author Report Posted February 8, 2006 problem solved:i had to drill bigger hole for the screws and i think drilling vibrations have created some 'micro-cuts' in my solders, i had to "resold" every pins of my PCB hope my probs could help ;Danyway thanks to TK ;)
TK. Posted February 8, 2006 Report Posted February 8, 2006 Great that some problems get solved even if nobody answers ;-)Best Regards, Thorsten.
