Popping noise. What am I doing wrong?
A few weeks ago I managed to program all my cores, thanks to TK.
I now have a four sid midibox sid, without Control Surface.
The man sid and core work perfect. However the three remaining sids only make a loud popping noise, even when I don't play a note.
I'm sure the problem is me, but it would be nice if someone could point me in the right direction.
It's quite strange the first sid/core works perfect and the other three not. Must be something in the wiring I guess.
Any help would be appreciated.
Thanks,
Rene
Hi Rene,
did you already try to swap the master with a slave PIC, just to check if this was a code upload problem?
  • 4 weeks later...
Sorry for the late respone. I was out of the country for a month or so.
Anyway, I tried your suggestion and swapped cores and sids.
I fount the problem. It turned out that sid 2 was broken and caused al the popping.
I feel also a bit like an idiot, because I made a realy stupid mistake. I forgot to press the link button.
Do al sids give sound now, but there's one problem left, which I will discuss in another post.
Thanks TK for your great help !!
Rene
