burnt the bankstick test f/w and plugged in the bank stick (new unused eeprom), LCD just reads 'Please connect/unconnect Stick'...
Tried with 2 eeproms - same message
Hi Dan,
so: something must be wrong with the BankStick interface. Could you make a high-resolution image of the upper half of your board and post it here? This would possibly allow me to give you more tips
;D ;D
i ended up just ripping that core out and using an old one that i restuffed - working midibox followed!!
no more error messages ;) the bankstick doesnt appear to work still but i think thats down to me a) wiring the pinouts wrong, or b) killing the eeprom when soldering on the pins - who knows? i'll check, and check, and check...
phew....
Finally...  :D
Perhaps some tracks of the not-working core module are not good enough, before you kick it into the trashcan you should try to fix the connections with small wires.
I must say that I still have respect for people who etched the boards by themself. I never did something similar, I always got support from friends with more experience in etching. Such imperfections during the first tries are quite normal - I would run into the same problems!
yeah, it already had a few wires beneath due to bad tracks :P - I was using the PNP for etchin (my attempts with the exposing/developing way resulted in 2 cracked glass sheets - which were from the coffee table!, due to the heat of the lamp - the lady was not impressed :o) - but they didnt come out the laser as clean as i expected (prolly due to the toner cartridge), once etched the tracks were pretty grainy and un-even...
has/is been tough tho, i came into this with NO EE knowledge what so-ever! the reason i wanted to etch myself was cos I wanna make MANY midiboxes - in the hope of finally having a studio that is totally custom to how i work...and this is/has/will be possible to that supercharged genius of yours! BIGUP THE T! :D
Nice1
Dan
So here it is...;)
Made this as a primer before i tackle bigger MB64 and MBLC. Def pleased with it, gonna use it as a portable jobbie - might wack a handle on the cover :p kinda midi lunchbox stylee....
Best...
Dan
