Hello all,
I just received some alps encoders with 24 detent and I'm figuring out how to get them connected.
Here is what I did so far:
1. Modified the mios_tables.inc > ENC_PIN_TABLE > set encoders 1-16 to MIOS_ENC_MODE_DETENTED2
2. Modified the setup_midibox64.asm > ENC_PIN_TABLE > set encoders 1-16 to MIOS_ENC_MODE_DETENTED2
3. Rebuilt the Application (No errors)
4. Uploaded the main.hex and then the setup_midibox64.HEX using MIOS Studio.
5. MIOS Rebooted
I tried connecting 1 encoder diffrent ways but it seems that when i turn the encoder it jumps from values 0 to 127 nothing in between.
I also tried setting the encoders to MIOS_ENC_MODE_DETENTED but same prob.
Thanks for your time  :)
villadon
Good news: Your enc most probably works out very well!
Most possible: Did you ever look up what´s your controller parameters? I guess it´s sending "Increment/Decrement" messages. If you want it sending 0-127 values in a row, you have to set it to "absolute" behaviour under Enc mode.
Greetz!
