disabling "fast" when changing layer?
how can i modify the code so that when i change the edited layer (note, velocity, length...) the fast button reset itself?
i often use the fast when i change the velocity, but then, when i come back to the note/gate event, i'd like to automatically disable the fast behaviour of encoders...
thanks!
The changes have to be made in seq_buttons.inc
Search for "SEQ_Button_Fast", add a label like "SEQ_Button_Fast_Direct" below the first #endif, and before the "data wheel" comment.
Now you can add following code below SEQ_BUTTON_LayerA (as an example):
  bcf SEQ_MODE0, SEQ_MODE0_FAST_ENCODERS, BANKED
  call SEQ_Button_Fast_Direct
