LED/Thru/COM Module with MidiBox Link
Hi all!
I build Midibox with 3 cores as MidiBox Link. I want to include LED/Thru/COM module, but I don't know if it is able with MB Link together. I don't want MIDIbox-to-COM, only LED monitor of MIDI mesages and MIDI Thru/2nd MIDI OUT. I'm not sure how to conect and if it is possible.
Thanks for reply
LX
You can do that on one LCD, onyl thing is following: MidiIn has to come from the first core (where the original MIDI In comes) and MidiOut has to come from the last core in the row (Link ending point). That´s all.
So three pins (V+/GND/MI) come from the Midibox link starting point, one pin (MO) comes from the last core.
*I think*  ;D
Greetz!
Hi pay_c
Yes, yes... ;D I have this wiring on my MidiBox Link, that's right. But I'm breaking my brain with question, how can I put the LTC Module in to the MB Liknk?  ???
Thanks
LX
Eeeeeeeeeerrrrrrrrrrr... I just explained...
See reply above. The LTC is connected to two different cores, it is NOT (as you might think) a part of the MBlink, it's more like lying parallel to it and copying just the defined In's and Out's. Just connect it like described and everyting should be ok.
Hi pay_c
Sorry, I'm stupid.... :-[
I uderstand now. Thanks for your patience.
Best regards
LX
Naaaaaaaaaaaaa, no problem at all. I know that for sure! Sometimes you´re sitting hours in front of the answer and don´t see it. That happens to me like every five minutes. ;)
Greetz!
