maniac Posted April 11, 2006 Report Share Posted April 11, 2006 Hi,I have a strange problem with JSynthLib. When I start the program everything works fine, but whet I try to modify envelope (only envelope, knobs and other controls works fine), jsynthlib starts to react very slowly. After that it’s impossible to edit patch. Only solution i have found is to close program and run it again.This is probably software/configuration problem connected with my new computer. I'have tested 3 versions of JSynthLib and always the same result - not only in Midibox sid editor, but also in other editors with envelope control.Maybe somebody had the same problem and can halp me ?My setup:Computer: WinXPJava: 1.5.0_06Midi: jamaha cbx driver (serial) / Emu 0404BestRegardsManiac / Przemek Quote Link to comment Share on other sites More sharing options...
TK. Posted April 11, 2006 Report Share Posted April 11, 2006 Hi,this could also be realted to the Java MIDI bug, are you using the workaround I've described at this page?-> http://www.ucapps.de/jsynthlib.htmlBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
maniac Posted April 13, 2006 Author Report Share Posted April 13, 2006 Yes, the reason of the problems was javabug. With midi midi-yoke/midi-ox everything works fine.Thank You Thorsten :-) Quote Link to comment Share on other sites More sharing options...
