anyone know good cheap supplyer in uk for some 2 way joystick pot's for my controller im soon to build. Thanks... :)
Also lookin for cheap miniture buttons with led's? for under £2 each?
I found great price for joysticks in uk for only £5.74 each or £53.30 for 10! It's part no: 252a103b60na-nd  at uk.digikey.com
Im also lookin for 128 miniture buttons with led's, must be cheap!! :)
As I can see in datasheet provided, joysticks are same ones I got from Sony Playstation joypad. I bought some on a fleamarket for les than 1 Euro. And you find 2 in one joypad. Recycle!
Did I say they work very good! You can leave or remove centralisation spring from it. Buton can be usefull 2. There`s post somewhere on the forum about it.
  • 2 weeks later...
Note - I too pulled apart a PS2 joypad - The joysticks are made by ALPS, btw.
Note about removing the spring: on the bottom of the stick, you'll see 4 tny crimp feet. pull them back a tad, and remove the bottom white thing from the stick - that is the "spring", not the actual spring inside the stick.
Also, the hole diameter on the joypad is 22 mm.  You'll need to round off (or better, bevel) the hole on your panel so that there isn't a sharp edge to cut the plastic stick.
  • 1 month later...
Q) Does the switch only illuminate when pushed? Or is it constantly illuminated? Or can it be configured as either? - D Willson
A) it is illuminated when in the 'on' position
That's no good :(
