toxictv101 Posted April 15, 2006 Posted April 15, 2006 dont know what happen <with my midi boxwhen i plug the midi cable into the "in"the screen get light, even if the power is not ON??????????? i wonder if it s not the ground of my computerthat is not the same of my midibox ???
smashtv Posted April 15, 2006 Posted April 15, 2006 Heya Toxic!Sounds like you are passing power through the Core MIDI out, not good at all...Clip the middle pin of Core:J13 (MIDI OUT) and see if this cures it.....if not there is another ground path (cases touching?).If you are using my Core R4 board and onboard jacks, cut the trace labeled "GND LIFT" between the holes....this has exactly the same effect as cutting J13:pin2.(I put the two pads/holes there so a 2 pin pinheader could be installed and jumpered drive select style if the trace is cut)Please let us know how it works out, I am compiling notes for a future wiki entry on this issue.BestSmashTV
toxictv101 Posted April 15, 2006 Author Posted April 15, 2006 hey,i m trying with a another computerand everythings is normali think that the midi out of my 1rst computer is outanyway this not work again :pi ll change the opto , i wonder if he s coulnt be out after that ... ???!!!
toxictv101 Posted April 15, 2006 Author Posted April 15, 2006 is it possible that my screen is brokenif it display only a line on the first caracter row???could it be the decoder inside that is out ???
banneduser Posted April 15, 2006 Posted April 15, 2006 Hi toxicWe would really like to help You, but You don't give enough information about your setup ect.if it display only a line on the first caracter row???Tells us that screen looks like initializing correctly. Can You see anything coming from the midibox -> PC midi input? Did your core module pass voltage tests as explained in the core module page at uCApps.de?ect.Moebius
toxictv101 Posted April 15, 2006 Author Posted April 15, 2006 hm.. hmthe screen always stay with the first line car. Black ( white)i would like to know if it would be because the screen is dead., i think that my lcd screen is brokenit was a prety expensive lcd 2x16 white with carr. and blue font"29€" snif snif :'(maby the midi cable with vdd on it was fatalbecause when i turn midibox it send midi messagelike it must do.and everything seem to be okexept this bad lcd, i ll change it now.
NorthernLightX Posted April 16, 2006 Posted April 16, 2006 I think (and hope) you didn't upload MIOS yet, because if you didn't, the behaviour you're reporting is exactly as expected. As in "perfectly normal working order".The MIDI message must be the PIC reporting itself as ready to be supplied with MIOS.
toxictv101 Posted April 18, 2006 Author Posted April 18, 2006 yop,yes everything was working well , exept the Expensive Blue/white led Lcdthat is BreaKed i Dont Know Why.With The NeW LCd everything is Ok , aNd Work Well ((( So if The First Line oF the LCd Stay Black , It can bE That the Lcd himself is OUT ))) :'(Tks To All For HelpAnd Enjoy diy Electronics ,,,Julien, BELGIuM
NorthernLightX Posted April 18, 2006 Posted April 18, 2006 yop,yes everything was working well , exept the Expensive Blue/white led Lcdthat is BreaKed i Dont Know Why.With The NeW LCd everything is Ok , aNd Work Well ((( So if The First Line oF the LCd Stay Black , It can bE That the Lcd himself is OUT ))) :'(Tks To All For HelpAnd Enjoy diy Electronics ,,,Julien, BELGIuMHi Julien,your keyboard looks broken too ;)Are you sure the problem with the LCD is not just a short or a miswire of some sort? I'd be happy to test it for you as soon as I have a Core online... (I'm in Holland)Cheers, Alex.
