toxictv101 Posted April 21, 2006 Posted April 21, 2006 hi alli ve finish to build a midiboxsidconfig is:1 sid modul1 core1 din and 1 Lcd 2x16i ve burn 3 powersuply adaptator until nowi dont understand ! ! ! is it Normalis the lcd or the sid modul can Kill it Juste like thisBecause I dont think there is a shortcut Inside !?!?!?!?!?!?!?!?!?!?!!!H.E.L.P
moebius Posted April 21, 2006 Posted April 21, 2006 Hi,No - This is not normal. What kind of Power Supply do You use? The combination of the modules and LCD should not take more than ~1A current, how much is your adapter rated for? Moebiusp.s. Some PSUs have thermal fuses in them, so they switch off if loaded too heavily and back on after the PSU calms down..
toxictv101 Posted April 21, 2006 Author Posted April 21, 2006 yhepi ve burn a alesis adaptator of 9vac 0.78A 7va a nintendo adaptator of 9v 1.3A and a 12 v 300mAthere is no shortchut between the + & - on power suply!!!!
moebius Posted April 21, 2006 Posted April 21, 2006 Then there is short somewhere in Your boards.. do a visual inspection if you can find a bad soldering and then use multimeter to check if there's short circuit somewhere.Moebius
toxictv101 Posted April 21, 2006 Author Posted April 21, 2006 the most strange isthat everything si working well "exept the filter (it was working very well, good cutoff, and after some notes it was very bad <,,,,,???)"the sid is not geting hot , neither the 7805 or 7809??? i think i must remove everything from the box and test everything :-\
toxictv101 Posted April 21, 2006 Author Posted April 21, 2006 i notice that adaptator burn only if i play soundout of the sid.
smashtv Posted April 21, 2006 Posted April 21, 2006 i notice that adaptator burn only if i play soundout of the sid.You have a power and or ground path from your SID to your amp, or your CORE to your PC, or both, or your CORE+SID are making a path from your PC to your amp, etc.The burnt out wal wart thing is totally related to your "display stays lit" issue.....Did you lift the ground on the CORE MIDI yet like I suggested on the lit display thread?BestSmash
toxictv101 Posted April 21, 2006 Author Posted April 21, 2006 no the lcd was break and i ve exange it from my dealer my sid can stay power on 2 hours without probsit s burn only if i make sound with it ???(((the power suply is in ac, but when i reverse the polarity it make a shortcute ))) also this , i dont understand .
