bill Posted April 22, 2006 Report Posted April 22, 2006 Hello,i definitely need help :i want to use the scan-matrix driver http://ucapps.de/mios/sm_example2_v1.zipwith C, (in order to drive the C64 keyboard http://www.midibox.org/forum/index.php?topic=6505.msg41509#msg41509) but i really dont know how to mix asm and CI tried to put required files into ./mios_wrapper/and include them into mios_wrapper.asm with no chancei have those errors :Assembling MIOS SDCC wrapper mios_wrapper\sm_simple.inc:193:Error [103] syntax error mios_wrapper\sm_simple.inc:194:Error [103] syntax error mios_wrapper\sm_simple.inc:195:Error [103] syntax error mios_wrapper\sm_simple.inc:196:Error [103] syntax error mios_wrapper\sm_simple.inc:197:Error [103] syntax error mios_wrapper\sm_simple.inc:198:Error [103] syntax error mios_wrapper\sm_simple.inc:199:Error [103] syntax error mios_wrapper\sm_simple.inc:200:Error [103] syntax error mios_wrapper\sm_simple.inc:204:Error [103] syntax error mios_wrapper\sm_simple.inc:313:Error [103] syntax error mios_wrapper\midi_evnt.inc:101:Error [103] syntax error mios_wrapper\macros.h:90:Error [151] Operand contains unresolvable labels or is too complex. mios_wrapper\macros.h:92:Error [151] Operand contains unresolvable labels or is too complex. mios_wrapper\midi_evnt.inc:271:Error [151] Operand contains unresolvable labels or is too complex. mios_wrapper\midi_evnt.inc:274:Error [151] Operand contains unresolvable labels or is too complex. ERROR!PLease help me if you can :-[
stryd_one Posted April 22, 2006 Report Posted April 22, 2006 http://www.midibox.org/forum/index.php?topic=5270.msg36662#msg36662 :)
bill Posted April 22, 2006 Author Report Posted April 22, 2006 Yes, thank you ! I understand "__asm" & "__endasm",but in fact, what i want (or 'hope') to do, is to mix the asm driver, with C code. Then it's lot more complicated (to me)
audiocommander Posted April 22, 2006 Report Posted April 22, 2006 well, I can't ASM and I don't know the example besides having taken a quick look.It seems that the SM_Stuff is that what you want to have, it shouldn't be very complicated but maybe a bit time-consuming to wrap it into a C-file with __asm and __endasm. on the other hand there are two more options:1. convert the whole asm project to C (I think most of the smaller projects will be converted to C sooner or later, so if you make a start, it surely will be apreciated) ;D2. forget the example and code your own application in plain C (I'd do that);) Michael
bill Posted April 22, 2006 Author Report Posted April 22, 2006 Well, the SM_Stuff, is a driver, not an application.For that reason, i think it should not be converted to CThank you anyway, i start learning ASM... ;)
audiocommander Posted April 22, 2006 Report Posted April 22, 2006 I call "application" what is based on the MIOS skeleton (Init(), Timer(), blabla).Therefore you can achive nearly all you want with a plain C custom application:You can disable the SRIO driver, setup a timer and scan and set pins of the pic. Besides the specialized de-/multiplexing that's apparently what the SM_example does (please correct me anyone if I am wrong).But am I right, that you want to use it for reading the state of your C64 Keyboard?If this is the case, you could just use a DIN module, check the pin states and demultiplex it by code. That sounds a lot easier.Anyway,good luck, Michael
TK. Posted April 24, 2006 Report Posted April 24, 2006 Sidenote: with the new mkmk.pl script (part of the most recent C wrapper release), it's possible to integrate assembly modules (.asm files) into a C project. The assembly code must be relocatable (means: it requires a data and code section, absolute addresses should not be specified).An example can be found in the midi router package, see MAKEFILE.SPEC how to add .asm files, and see int_midi.asm/int_midi.h, how a relocatable module looks likeBest Regards, Thorsten.
audiocommander Posted April 25, 2006 Report Posted April 25, 2006 Hi Bill,as mentioned, I'm not the guy to do ASM, so please don't see my solution as the quickest, best or fastest; but if you can code C it may be the easiest - if that what you get from the keyboard are really just encoded ON/OFF states (I don't know about PS/2 or whatever signals may come out of a keyboard), I would proceed like this:- add a DIN to your Core- connect the 8 wires from the Keyboard to 8 DIN pins- setup a global variable c64matrix[8]; to save space you could create a bitfield.- now you just have to use the DIN_NotifyToggle() Function,just place your appropriate handler there. It will notify you whenever a state is switching. Use the global c64matrix to prevent having to check all the other seven pins on notify toggle: ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { // update the matrix c64matrix[pin] = value; // check what to do switch(c64matrix) { case 0x00: // e.g. key '0' pressed do_that(); break; case 0x01: // e.g. key 'a' pressed do_this(); break; default: do_nothing(); break; } } I think, this might be easy, if the keyboard is really just en-/decoding states;;)Regards,Michael
