Davo Posted April 25, 2006 Posted April 25, 2006 I'm checking out a C64 using the "Music Machine" cartridge. I figure that ought to be a halfway decent and quick exercise of the SID. Anyhow, this C64 has a dodgy keyboard, but I'm able to get one key to make a sound. Repeated presses of the key causes the same note to appear onscreen, but each time, it gradually rises in pitch by maybe an eighth of a step. After maybe 20 presses, the note is constant. Is this a good SID or a bad SID? What would be a better SID test?
TK. Posted April 26, 2006 Posted April 26, 2006 I don't think that this is a bad SID, it seems to be a feature of the software (e.g. an envelope on the pitch?)If you hear any sound, you can be sure, that the SID is okBest Regards, Thorsten.
Davo Posted April 26, 2006 Author Posted April 26, 2006 I also determined that the SID is good, but was left puzzled. I put the SID in question into a known good machine and tested with the same Music Machine cartridge. The SID sounded great. I then tried the good machine using the bad keyboard. Problem reappeared. Put the SID back in the first machine and plugged in a known-good keyboard. The SID sounded great. So, the keyboard was somehow able to cause this odd problem.Regarding hearing any sound indicated a good SID, I've heard that some SIDs can have good oscillators but bad filters. I wish I could find my Frogger2 cart. That was a good sound test.
TK. Posted April 26, 2006 Posted April 26, 2006 Yes, especially the newer (shrinked) 6581 versions which were produced 1984 and later have bad filters - if good filter sound and low noisefloor is desired, consider the use of a 8580Best Regards, Thorsten.
Davo Posted April 27, 2006 Author Posted April 27, 2006 I've been trying to get 8580s and just not realized that only certain C64Cs have the 8580 chip. So I now have six 6581 SIDs of varying vintages and one 8580 still in the computer. How do I determine a shrinked 6581 from the markings on top?
TK. Posted April 27, 2006 Posted April 27, 2006 How do I determine a shrinked 6581 from the markings on top?there isn't that much documentation available about this, but the lower line shows the production date which gives a hintBest Regards, Thorsten.
