Been trying to figure out a way to use slide switches instead of faders, but....
Any recommendations would be appreciated, even if they are cost prohibitive (all my ideas are :P)
Hello, yes those are slide switches.  I want to make a LC Midi box but I don't need all of the analog values of a fader.  Just something like a 5 position slider switch, but I want to be able to do midi recall of their positions.
A motorized fader would work if they have those with detents.  However, I initially started thinking of other ways to accomplish this a little more cheaply since I don't need faders, just really switches.
Maybe it's clearer if I call it a motorized 5 position selector switch?
What other info. would be helpful?
I don't understand what you mean by 'MIDI recall'. Can you explain step-by-step what you want to do?
No, not really. Switches aren't motorized.
-drin
you want to be able to select 5 values of a parameter instead of going trough the whole range of the parameter, right? and you want to see which value is selected when you choose a different program/preset?
you can make this with 5 buttons and led indicators but you would probably have to write some code so the leds work the way you want
I was thinking of what illogik said with five buttons, or otherwise you could just quantize the values on a fader.
