Thomas Posted May 12, 2006 Posted May 12, 2006 Hallo!It seems not possible to create large char-arrays with more than 256 elements. Is this correct? unsigned char myArray[256]; //okunsigned char myArray[257]; //I'll get "no more memory" compiler errorBut: unsigned char myArray0[256]; unsigned char myArray1[256]; work. It seems it's not a problem of too less remainig memory (registers) but the addressing with only a 8bit.
audiocommander Posted May 12, 2006 Posted May 12, 2006 Maybe this is SDCC related?I noticed that it's not possible to define a bitfield with more than 8 bits.But this doesn't seem to be a big handicap, right? ;)Michael
Thomas Posted May 13, 2006 Author Posted May 13, 2006 No, this is no handicap. I just wanted to know this. I contacted the programmer who wrote the PIC16 part of the sdcc project. Sadly there is no complete documentation avaiable.Especially not for code optimization. (How to programm, what to avoid etc.pp.) Btw. large arrays can be created in the linker script.
stryd_one Posted May 13, 2006 Posted May 13, 2006 Btw. large arrays can be created in the linker script. Would you mind telling us a little more about this thomas?
Thomas Posted May 13, 2006 Author Posted May 13, 2006 Ok. (Hoping that it's ok to publish private mail) Vangelis Rokas wrote: 1.)For example, when declaring functions with pointer arguments that youalready know they point at RAM memory, do not declare them like this:void f(char *str);but like this: void f(__data char *str);The __data specifier uses only 2 bytes for the 'str' pointer, when it wouldneed 3 bytes (and more instructions to handle read/writing, etc...)This is just the tip of the iceberg(!) but I don't have everything on handright now...2.) (large arrays)This can be solved by tweaking the .lkr script.Concatenate some DATABANK entries for example://DATABANK NAME=gpr3 START=0x300 END=0x3FF//DATABANK NAME=gpr4 START=0x400 END=0x4FF//DATABANK NAME=gpr5 START=0x500 END=0x5FFDATABANK NAME=gpr345 START=0x300 END=0x5FF // this createsa segment 3 * 256 bytesThis way you could allocate the whole data ram of a pic in a single DATABANKand allocate as much of it you can afford!!!! :-)Greetings Thomas
stryd_one Posted May 13, 2006 Posted May 13, 2006 Thanks to you both :)...a bit over my head though ;) I'm not sure how the databank addresses relate to the C variables.
th0mas Posted May 16, 2006 Posted May 16, 2006 I'm not sure how the databank addresses relate to the C variables.In C when you declare an array you are really allocating a portion of memory and storing the start of that portion in the array variable. So:unsigned char b[200];means "allocate 200 bytes, and store the address of the start of that newly allocated block in b".So b is really just a pointer to a memory location. So the linker script above is just allocating the memory and giving it a name, but not doing it in C:DATABANK NAME=gpr345 START=0x300 END=0x5FFObviously the harder part is that you have to explicitly give it the start/end positions, which if you use C syntax to allocate the block the compiler/linker does it for you.Just to complete the example: when you access an array element, likeb[200] = 5;You are really saying "add 200*sizeof(any array element in b) to the address stored in b, and store 5 at that memory address".Hope that makes sense stryd_one :).
stryd_one Posted May 16, 2006 Posted May 16, 2006 Ahhh lovely now I can relate it to some of the ASM I know :) (Which is probably what the compiler makes the arrays into heheh)The thing I really don't get is how our array called 'b' matches up with the linker script, I mean, do we need to add the array's name and memory space to the linker every time we create an array?Today I've got that "I should have stuck with ASM" feeling ;)
audiocommander Posted May 16, 2006 Posted May 16, 2006 don't worry stryd_one, I don't get it either.Although it's interesting having read that such a possibility exists, I would leave my fingers from it. This sounds really dangerous, because it contains several traps to step into if you're changing smth later...If you really need more than 256 array elements, it might be of wiser to group the items and use some #defines(Besides 256 AINs? 256 LED's? No... maybe 256 DIN's? Man, that seems like button-hell ;D I just counted 110 keys on my computer's keyboard... )
th0mas Posted May 16, 2006 Posted May 16, 2006 The thing I really don't get is how our array called 'b' matches up with the linker script, I mean, do we need to add the array's name and memory space to the linker every time we create an array?Apparently only when it's >256 bytes (or maybe 256 elements, you'd have to try)
Thomas Posted May 17, 2006 Author Posted May 17, 2006 Hi!As audiocommander said, it's better to use groups of <=256 arrays. On reason is that only a char (8-bit) is used instead of an 16bit int what would require at least the doubled number of assembler commands. (-> see the resulting *.asm file after compiling) Ways to access a database defined like mentioned above: 1.) Use the absolute address: unsigned char * ptr = 0x300; ptr[0] = 0x08;ptr[1] = 0x15; ...2.) Use symbolic name, but I havn't tried this: (from Vangelis)Another way to define a symbol at a specific databank would be to use the'udata' pragma. The usage would be:#pragma udata array_name gpr345_sectionThis would 'array_name' at gpr345_section DATABANK (which would that be...)But then you would have to add one more line in the .lkr script file:SECTION NAME=gpr345_section RAM=gpr345
stryd_one Posted June 25, 2006 Posted June 25, 2006 Good news guys, I've been doing some experimentation and have figured out what's going on with all this drama about large data storage and arrays. I'll write a documentation on the wiki shortly with full instructions.Before I do, I just need to find out some info about memory use on the 4620 so I can document that too.... But that's one for another thread.In short: Arrays can be addressed with >8bit indexes, no problem, but they attempt to allocate more ram than is available. The symbolic name trick from vangelis (and the sdcc manual) posted previously works like a charm :)
stryd_one Posted June 30, 2006 Posted June 30, 2006 You can find documentation on how to alter the linker script for larger variables (including big arrays), as a part of the doco for using the 4620:http://www.midibox.org/dokuwiki/doku.php?id=application_development#cHope this helps.
stryd_one Posted February 11, 2008 Posted February 11, 2008 I noticed that it's not possible to define a bitfield with more than 8 bits.For the record:Good news, I have just tested a 15-bit bitfield (15, not 16, to test correct alignment of odd sizes across bytes), and all accesses are correct :)This was with a post 2.7.0 SDCC release.
nILS Posted February 11, 2008 Posted February 11, 2008 For the record...You're gonna copy-paste that in every thread now? ;-)
stryd_one Posted February 11, 2008 Posted February 11, 2008 Well, a lot of us use those threads as reference points, especially a good newbie doing a search to find out info. Several of them are linked from wiki articles too... If I put this info in one thread, they may miss it, so it's in the threads where it was said that the limit was 8 bit, as an update to the existing doco.Sorry for the annoyance, but it's important, for future reference :)
