DavidBanner Posted May 29, 2006 Posted May 29, 2006 Hi folks,My core was working fine and I was trying to get my LCD working when it went nuts and started reseting continuously, so I took the LCD off and left it alone for an hour or so.So now it's sending out the program request every 2 seconds, but it won't upload properly.When I try to upload it does the first block and then freezes - see the screen capture below. Please note the weird sysex msg it sends before it freezes:F0 00 00 7E 40 00 0E 0B 01 F7I get this no matter what program I try to upload - I've tried everything from MIOS1.9 to the apps like LC etc :( Any ideas??
th0mas Posted May 29, 2006 Posted May 29, 2006 Your MIDI signal from your computer to your CORE is not working. Otherwise after the first block was sent, the CORE would send back a CHECKSUM message instead of an UPLOAD REQUEST message.
DavidBanner Posted May 29, 2006 Author Posted May 29, 2006 I didn't expect that to be the case, as everything was working fine before and I've already pluged and unplug the midi stuff to be sure - but I decided to give the midi ports a wiggle and the board a little shake and tap....an lo and behold! I can upload again!yay!thanksnow, to try to get the LCD to behave it's self....
