d2k Posted March 16, 2003 Posted March 16, 2003 Hi...T, are there any test firmwares that'll work on the 18F with the MF module connected to test the motor faders? Also, the PDF link for mbhp_mf_interconnections.pdf on the site is dead, can u send it me pls? Finally, how do utilise touch sensors capability with these panasonic faders, can it be done?Cheers...Dan
TK. Posted March 17, 2003 Posted March 17, 2003 Hi Dan,it seems that I've removed this pdf by fault - also on my harddisc :-(So it could take some days until I find the time to create the diagram once more.However, the required interconnections can already be found in the MF schematic. The simplest test program for the MF module is the "mf_calibration" application.Touch sensors: I don't own panasonic faders, therefore I cannot say if there is a solutionBest Regards, Thorsten.
d2k Posted March 17, 2003 Author Posted March 17, 2003 okay, np on the pdf - i can see now that the faders are just connected as regular pots, it's just the pins of the motor itself connected to the MF module...Ye, shudda seen that MF calibration test - been to that page enough times ;pThanks...BTW: For the LC emu, where are the LED rings connected for the encoders, as the MF module is already using J7 of the 18F core?...
TK. Posted March 17, 2003 Posted March 17, 2003 They are connected to the common DOUT chainBest Regards, Thorsten.
