bootloader and mios upload
Shum
Great that you finally solved this!
Now we especially know, how the bootloader reacts on a bad supply voltage.
Shum, could you please test the upload of the application with MIOS Studio? I just only want to know, if it works reliable on your computer
TK maybee you should add to the MIDI debuging guide a pover supply check. It seems to me that PSu is a "troublemaker" with many failed MIOS uploads. Just something like:
"Check the voltage on J2, if it is ______V than everything should be ok with your PSu."
Hi Thorsten,
Loaded the bootloader with burner to the pic. Uploaded MIOS with MIOS Studio_v7 successfully. Thereafter uploaded the midibox64 application without fail. The uploading was very smooth and fast.
I got the feeling that the pic18f452 is more susceptible to noise than the older 16f877. For those who are using switching power supply unit to power the core, there is a need to have additional smoothing and noise trap circuit to ensure the quality of the supply.
I took the liberty to include here an additional circuit for those who are going to use switching power supply. This is in response to Digispunk's posting
Best regards
Shum
70_psu_jpgbbfe33583c6a0755173ee4075c230a
