Hallo!
I need some input for programming.
I want to write a routine for editing same valus, the midi events of a button or poti.
A button has 4 midibytes (controller command, value1, valueOn, valueOff, type)
(if you now the PC1600 from peavey you'll know what I mean)
it's looking like this on the display (T==toggle):
old: BE017F01T
new: BE017F01T
Now I want to add a cursor, like
old: BE017F01T
new: BE017F01T
(indicating that you edit the lower nipple of the second midi byte)
My current solution is:
old: BE017F01T
new: BE0>1<7F01T
But this looks ugly.
Any Ideas?
  • 4 years later...
does someone know how to make this cursor at the good position ??? it appears on the 4th line (adress 0xc0) on a 4x20 LCD
i can edit the EditBuffer but the cursor don't want to move :getlost:
#include <cmios.h>
#include "chaosmatrix.h"
#include "softpanel.h"
#include "lcd.h"
#include "din.h"
#include "midi.h"
#include "patchnames.h"
#include "memo.h"
#include "ui_patch.h"
unsigned char banksaved;
unsigned char programsaved;
unsigned char saved;
static unsigned char cursor;
    EDIT PAGE 1
    12345678901234567890
    SELECT EDIT GROUP
    LFO VCA ENV PRTA RMP
    EDIT PAGE 3
    BNK SAVE PATCH?
    0   abcdeghj:00 save
 EDIT PAGE 2
 0123567890123567890
	uOOO ________
  <   > editname save
  o   o   *    *   o
// Display for edit
void UI_Display_Edit (void)
	unsigned char i;
    switch(SoftPanel.Page)
		case SOFT_PAGE1:
            MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_PATCH].dout_pin);			// off
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_EDIT].dout_pin); 			// on
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_OSCILLATORS].dout_pin); 	// on
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_FILTER].dout_pin); 		    // on
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_ENVELOPES].dout_pin); 	    // on
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_KEYBOARD].dout_pin); 		// on
			MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_MATRIX].dout_pin); 		    // on
            MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_PAGE].dout_pin); 		    // off
            MIOS_LCD_Clear();
			MIOS_LCD_CursorSet(0 + LCD_Offset);
            MIOS_LCD_PrintCString("SELECT EDIT GROUP");
            MIOS_LCD_CursorSet(64 + LCD_Offset);
            MIOS_LCD_PrintCString("LFO VCA ENV PRTA RMP");
		break;
		case SOFT_PAGE3: // save patch to matrix1000 memory
            if(SoftPanel.IsNewPage)
                MIOS_LCD_Clear();
                MIOS_LCD_PrintCString("OSC BEND MODW PORTA");
                MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_EDIT].dout_pin); 			// off
                MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_OSCILLATORS].dout_pin); 	// off
                MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_FILTER].dout_pin); 		    // off
                MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_ENVELOPES].dout_pin); 	    // off
                MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_KEYBOARD].dout_pin); 		// off
                MIOS_DOUT_PinSet0(DIN_ConfigMap[DIN_MATRIX].dout_pin); 		    // off
                MIOS_DOUT_PinSet1(DIN_ConfigMap[DIN_PAGE].dout_pin); 		    // on
                MIOS_LCD_Clear();
                MIOS_LCD_PrintCString("BNK SAVE PATCH ");
                MIOS_LCD_PrintBCD1(BankNumber);
                MIOS_LCD_PrintBCD2(ProgramNumber);
                if(ProgramNumber < 10)
                    MIOS_LCD_CursorSet(16 + LCD_Offset);
                    MIOS_LCD_PrintChar('0'); // place a zero here for values below 10
                saved = 0;
            MIOS_LCD_PrintBCD1(banksaved);
            MIOS_LCD_CursorSet(64+4 + LCD_Offset);
            MIOS_LCD_PrintCString(PatchNames[banksaved][programsaved]);
            MIOS_LCD_PrintChar(':');
            MIOS_LCD_PrintBCD2(programsaved);
             if(programsaved < 10)
                MIOS_LCD_CursorSet(64+13 + LCD_Offset);
            MIOS_LCD_CursorSet(64+16 + LCD_Offset);
            if(!saved)
                MIOS_LCD_PrintCString("save");
            else
            MIOS_LCD_PrintCString("    ");
		break;
		case SOFT_PAGE2: // name the patch
            //if(SoftPanel.IsNewPage)
				 EDIT PAGE 2
				    uOOO ________
				 <   >  editname save
				 o   o   *    *   o
				//1st line
                MIOS_LCD_Clear();
				MIOS_LCD_CursorSet(1 + LCD_Offset);
                MIOS_LCD_PrintCString("u");
                MIOS_LCD_PrintBCD2(uBS_uBank);
                MIOS_LCD_PrintBCD2(uBS_uPatch);
			    // place a zero here for values below 10 (bank & patch) :
				if(uBS_uBank < 10){
					MIOS_LCD_CursorSet(2 + LCD_Offset);
                if(uBS_uPatch < 10){
                    MIOS_LCD_CursorSet(4 + LCD_Offset);
				MIOS_LCD_CursorSet(7 + LCD_Offset);
                MIOS_LCD_PrintCString(":");
				// print patch name :
                MIOS_LCD_CursorSet(9 + LCD_Offset);
				for(i=0; i<8; i++){
					MIOS_LCD_PrintChar(EditBuffer[i]);
			//cursor
			//MIOS_LCD_CursorSet(cursor + 9 + LCD_Offset);
			MIOS_LCD_Cmd(0x80 + cursor + 9 + LCD_Offset);
			MIOS_LCD_Cmd(0x0e);
			// 2nd line
            MIOS_LCD_CursorSet(65 + LCD_Offset);
            MIOS_LCD_PrintCString("<");
            MIOS_LCD_CursorSet(69 + LCD_Offset);
			MIOS_LCD_PrintCString(">");
			MIOS_LCD_CursorSet(71 + LCD_Offset);
			MIOS_LCD_PrintCString("EditName SAVE");
			break;
// Handle for Edit
void UI_Handle_Edit(void)
    if(SoftPanel.Page == SOFT_PAGE1){
        switch (SoftPanel.Button)
            case DIN_PAGE:
                SoftPanel.Page = SOFT_PAGE2;
            break;
	else if(SoftPanel.Page == SOFT_PAGE2){
		switch (SoftPanel.Button){
            case DIN_PAGE:
				SoftPanel.Page = SOFT_PAGE3;
				break;
            case SOFT_EDIT_1: // "<"
				cursor--;
				MIOS_LCD_Cmd(0x10);
				break;
            case SOFT_EDIT_2: // ">"
				cursor++;
				MIOS_LCD_Cmd(0x14);
				break;
				case SOFT_EDIT_5:
				Write_Patch_To_BS(uBS_uBank,uBS_uPatch);
				break;
            case DIN_EDIT:
					SoftPanel.Page = SOFT_PAGE1;
				break;
		//if(SoftPanel.EncoderValue != 0){
            // encoder
            EditBuffer[cursor] += SoftPanel.EncoderValue;
			if (cursor > 7)
				cursor = 0;
	else{ // page 3
            case DIN_PAGE:
				if(!RefreshSoftPanel)
				break;
            case SOFT_EDIT_1:
                if(!RefreshSoftPanel){
                    banksaved = banksaved == 0 ? 1 : 0;
                    saved = 0;
				break;
            case SOFT_EDIT_5:
                    MIDI_SavePatch(banksaved, programsaved);
                    saved = 1;
				break;
            case DIN_EDIT:
				break;
            // encoder
            programsaved += SoftPanel.EncoderValue;
            if(programsaved > 99)
                programsaved = 0;
                programsaved = 99;
            saved = 0;
        } // end if encoder
	} // end else page 2
