stryd_one Posted February 24, 2007 Posted February 24, 2007 Well to be honest I actually planned on using QBAS's code sending keypresses to the MK. Basically it's a cheap keybed to me, but I do wish I was about to trash something less rare :-\Unfortunately I didn't get a cable, and haven't been able to track down so much as a pinout :( I don't know if these things are meant to be velocity sensitive or what, and I fear destroying a perfectly good velocity/aftertouch sensitive keyboard matrix decoder may be ahead of me :(If you have any info about these things it'd be great, or if you want to swap a similar board of lesser collector's value for it, just say the word and she's yours.
TheAncientOne Posted February 25, 2007 Posted February 25, 2007 Hi StrydI dug out the Keyboard IO card and did a rough pin check. This might be enough for a start. The cable seems to be a 25 pin straight through as far as I can see, so far.I finally weakened and unearthed the keyboard tonight, (hence the edit). You'll need to open yours over a sheet of newspaper or something - it's got the same crumbly foam around the key edges as under a Moog MG1 control panel. I didn't and my table is covered in sticky foam debris. It seems to be scanned in groups of eight and has a single wire per key, moving between a pair of bus bars, which indicates that it is velocity sensative. The bus bars are in eight pairs. It's scanned from the host - there is no on-board intelligence. The two 1/4" jack sockets are for pedals, they may be velocity sensitive too - they are on stereo jacks. Key isolation is by germanium diode, possibly a worry about volt drop. Keyboard electronics is a 74154 and two 74367's I'll beep out the circuits if I get a bit more time, but it looks to me like a simple I/O could be hooked to the existing circuitry. I've not got a full sized keyboard myself, so perhaps there might be a bit of a joint project here.Since a list of Apple IO pins is not exactly MIDIbox relevent, I've sent you them as a memo. Note this was earlier, and is just the Apple 2 end card.Hope it's some use - I'd always rather make an add-on than butcher rarities. I do know the keyboard cards for the Syntauri are rare, though I seem to remember seeing another one in one of the boxes. I've just found a whole load of cards I coiuldn't remember getting either. Apple Z80 card... now where did that come from? so there is hope. You'll need to keep a lookout for the Mountain hardware thingy - it's two Apple cards hardwired together with a ribbon cable, with flying lead phono connectors, and if you're lucky, a light pen.I'm in the UK, so a swap might be a problem - though if I find the other IO card, it might be cheap to mail you that, if you fancy trying a resurrection, (though more like necromancy I think!).Best wishesMike
stryd_one Posted February 26, 2007 Posted February 26, 2007 Thanks man :)I don't think I'll attempt the resurrection unfortunately, don't quite have the resources, but with that info I should be able to get the thing going as a midi keyboard and have it remain intact so that it could be resurrected by someone later on. I know it's historical value and I'm really glad I won't have to destroy it, so thanks man!
